Activity Forums Adobe Premiere Pro Tricky Audio Track – Can’t Edit Audio track
  • Tricky Audio Track – Can’t Edit Audio track
    Posted by Phil Lebeau on June 27, 2012 at 5:25 pm
    So, I had an audio track that I could not move, select, edit or cut….
    THEN I found out why. Hopefully this will help others 🙂
    if the track is set to show CLIP keyframes you can edit the track
    If the track is set to show TRACK keyframes, you can’t edit the track
    Phil LeBeau
    http://www.phillebeau.com
    Nicola Hammond replied 9 years, 9 months ago 5 Members · 5 Replies
  • Ann Bens
    June 28, 2012 at 6:28 pm
    Can get a bit confusing:
    If its set to Show Clip Keyframes you can edit the audio clips but not the audio track.
    If its set to Show Track Keyframes you can edit the audio track but not the audio clips.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Rex Brown
    September 9, 2013 at 7:15 pm
    THANK YOU.
    “The emptiest boxcar always makes the most noise.”
    Maduko World Headquarters
  • Nicola Hammond
    November 21, 2016 at 2:44 pm
    Thank you SO MUCH !!
    NH
  • Duke Sweden
    November 21, 2016 at 4:51 pm
    Yeah, this seems to be a new “feature”. Was trying to keyframe an audio clip last night but the keyframe button was grayed out. I accidentally stumbled upon that dropdown that lets you change the setting. But then my keyframe extended to infinity past the clip and no way to trim it back. Luckily it doesn’t cause the entire sequence to extend the length of the keyframe line.
    Was this feature totally necessary!!
  • Nicola Hammond
    November 21, 2016 at 5:11 pm
    Don’t you just love all these things to catch us out! Hope it all works out and many thanks again for sorting this beginner out!
