Activity Forums VEGAS Pro Trialing Vegas 10 HD
  • Trialing Vegas 10 HD
    Posted by Mark Saavedra on November 4, 2010 at 8:05 pm
    I am trialing Vegas 10 HD and have a quesion on rendering. I am rendering video, about 35 minutes in length, after adding some disolves and titles. The rendering box shows approx. 2H 20M to complete the rendering task. The video is in AVCHD format at 1440X1080i and I am using the 1440X1080i template on output. Is 2 hours a resonable amount of time to render 35 minutes of video in AVCHD output format? My prior video editing tool was premiere elements 3.o which doesn’t support AVCHD formated files and I was not impressed with the latest release of premiere elements from all ofthe bug reports folks using it are reporting. I’m running the software on a Intel Core 2 Quad Q9450 @ 2.66 GHz with 3G Mem running Vista 32 bit OS.
    Mark Saavedra replied 15 years, 9 months ago 3 Members · 3 Replies
  • Frederic Baumann
    November 13, 2010 at 6:52 pm
    I think this timing is realistic.
    With an i7-950, under 7/64 and Vegas Pro 10, I have about 1’30 of rendering per minute of movie (with no effects), rendering 1920×1080 clips to 1280×720 output with the Sony AVC plug-in (target is MP4).
    rendering to 1920×1080 instead of 1280×720 is about twice as long.
    So, considering your hardware, I believe your timing is more or less normal.
    Looking for a white balance plug-in? Visit my web site.
    Want to learn on Sony Vegas Event Pan/Crop tool? Watch my video tutorial:
    https://library.creativecow.net/baumann_frederic/Sony-Vegas_event-pan-crop-tool/1
    Or about Keyframes? https://library.creativecow.net/articles/baumann_frederic/Animating-with-Keyframes-in-Sony-Vegas.php
    French version: https://geo.creativecow.net/fr/a/12999
  • Al Bergstein
    November 15, 2010 at 8:02 am
    I have an i5 w/8 GBs RAM, quad cores, and W7 64x w/Vegas 10 (Trial) and 9e. I think your rendering time is accurate, but would wonder what your times would be if you convert to AVI using Neoscene and then render out. It’s supposed to be a lot more efficient to use AVI for rendering and editing than AVCHD. I still edit in AVCHD for some small jobs, but neoscene so easy to convert that I’m doing it more and more. It *seems* to be reducing my render times, but no tests yet. Converting is batch process that’s very easy and fast. (I just converted 5 clips to AVI that were shot on MOV/AVC format (Canon 7d) and the entire conversion took 33 minutes. I’ve not yet rendered out the content. Maybe I’ll to it tonight.
    Update: I just completed the 28 minute clip, rendering the AVI HD video from the Canon 7d (transcoded from MOV to AVI) into Sony AVC for SD output to Vimeo. Looks like I’m getting 28 minutes in 30 minutes for this kind of output on this machine. I’m happy.
    Alf
  • Mark Saavedra
    November 15, 2010 at 9:54 pm
    Thank you all for replying to my question. Your responses have been helpful to me as I make a decision as to which software suite I will purchase.
    Regards
    Mark
