Activity Forums Adobe After Effects Trembling line effect in after effects
  • Trembling line effect in after effects
    Posted by Oleksandr Hants on September 21, 2015 at 9:50 pm
    Hi all! Maybe this question is stupid, but I still don’t understand how to do a trembling(shake) line effect in after effects. I talk about effect like in this video https://vimeo.com/134093425
    It’s remind me handrawing animation. Maybe they use displacement map effect with some dusty animated textures? And i don’t think that this is wiggle paths effect in the shape layer. Would be nice to hear your thoughts about how to create this animation style.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Oleksandr Hants replied 10 years, 12 months ago 3 Members · 4 Replies
  • Crasse Deux
    September 22, 2015 at 9:30 am
    Hi !
    in your example video, I think base material is vector drawing, Imported in AE and turned into shape layers, with a “wiggle paths” Added to it (from the “Add” drop-down menu of the shape layer).
    more details here (the wiggle path part start a 2:40) :
    https://www.youtube.com/watch?v=sAlZt0qWOz4
    also, you can decrease framerate (between 12 to 16 fps) to give it a “hand made” feel using the Posterize Time over your precomped main composition.
  • Daniel Waldron
    September 22, 2015 at 2:53 pm
    Check out this tutorial.
  • Oleksandr Hants
    September 22, 2015 at 8:33 pm
    Thank you, it’s a good idea, but I need something a little more dusty and random. In any case, I will try your method.
  • Oleksandr Hants
    September 22, 2015 at 10:11 pm
    Oh, thank you, I think this is what I need!
