Activity › Forums › Apple Motion › Travelling Line
  • Travelling Line
    Posted by Anna Panetta on March 27, 2006 at 1:56 am
    Hi There,
    I have received some information on what I need, but typically, I can’t locate it when I need to. I was wondering if anyone knows how this is done. I am doing a DVD for a client using FCP5. The client migrated from Italy to Australia by boat, and ideally, what I would like to do is have a map of italy, with an arrow travelling from Italy to Australia. I hope this is making sense. Hope someone can help me.
    Cheers
    Anna
    Anna Panetta replied 20 years, 6 months ago 4 Members · 4 Replies
  • Pol
    March 27, 2006 at 11:07 am
    With motion 1 you can use a particle emmiter. Set speed to zero and make a motion path, use a circle as particle.
    In motion 2 you can use the replicator also.
  • Sean Lacanita
    March 27, 2006 at 5:25 pm
    Another technique:
    Depending on the line, one can mask it with an appropriate shape and then animate the mask to reveal the line.
    A tip: drop the opacity of the mask while keyframing it so you can see the line under it as you work.
    You can also rotate the mask so the end of the line stays ‘square’.
    Personally, I think the motion path and a small circle previously mentioned is the best approach and can handle any line shape.
  • Chris Cleaver
    March 29, 2006 at 12:54 am
    This is from I believe “specialcase’s” web site on Motion called Motion Smarts (great web site by the way). I think this is what you are looking to do(?).
    https://www.motionsmarts.com/tutorials/drawinglines/drawinglines1.html
    HTH,
    Chris
  • Anna Panetta
    March 29, 2006 at 10:17 am
    thanks for your help. It’s exactly what I was looking for. You were right, it is a good web site!
    cheers
    anna
