Activity › Forums › Apple Final Cut Pro Legacy › traveling with mac book pro
  • traveling with mac book pro
    Posted by Tom Maloney on August 18, 2006 at 8:41 pm
    Hi all here is my basic question, I edit at home using the macbook pro and store all files related to my FCP project to a external Lacie hd. No problems at all, everything works fine. I have to do so traveling, will take the hd with me fo ruse at the hotel. How can I edit on a plane with out using the hd , copy all files to my system drive and then later copy them back to the external drive ? I know FCP will ask for the portable hd if that is where the files are stored
    thanks
    all
    new to Macs and FCP here
    Tom
    Richard Harrington replied 20 years, 1 month ago 3 Members · 2 Replies
  • Todd Gillespie
    August 18, 2006 at 11:01 pm
    [tom] “How can I edit on a plane with out using the hd , copy all files to my system drive and then later copy them back to the external drive ?”
    If you are using proper file management, then you should be able to drag over the couple of media folders, as well as the project file, then relink it in FCP and you should be good to go.
    It must be a really long flight if you are going to try to do some heavy editing while your flying…
    If you have the money, it would be easier to invest in a micro FW drive that gets power from your laptop. THen you might be able to plug in your drive and keep working. Although with the airline scare, all bets are off.
    Good Luck,
    Todd at UCSB
    Television Production
  • Richard Harrington
    August 20, 2006 at 12:17 am
    slightly more advanced.. is using Offlien RT
    Boot laptop into Target Disk Mode.. Hodl Down T at startup
    Plug it into tower
    Rn media manager… target disk and create a version of the project at Offlien RT mode
    Do not delete unused media or change handle length
    Edit
    When Done… Create Offline project with Media Manager and relink to Main media
    This workflow is adewuately described in documentation
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
