Activity › Forums › Apple Final Cut Pro Legacy › Traveling masks
Traveling masks
Posted by Mariad on November 9, 2007 at 8:04 pmHello,
Could you please tell me if FCP features traveling masks?
Thanks.Nick Meyers replied 18 years, 10 months ago 4 Members · 3 Replies -
Russell Lasson
November 9, 2007 at 8:40 pmYou mean Traveling Masks the rock band on iTunes? 🙂 jk
But seriously, do you mean a keyframed mask or using a alpha or luma matte or something? (It does all of these that I mentioned) Are you referring to something different?
-Russ
Arnie Schlissel
November 9, 2007 at 9:57 pmIf you mean Rotoscoping, no. You can add Silhouette Roto as a plugin or stand alone if you need to rotoscope a lot. You can also use Motion for simple to medium duty rotoscoping. Or you can rotoscope in a separate application like Shake, After Effects or Combustion.
If you’re asking if you can use an existing traveling matte to a shot to cut it out, yes. That’s done quite easily.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Nick Meyers
November 10, 2007 at 8:17 amfor VERY simple work you can keyframe the built-in 8-point garbage matte.
for more complex work there are some FREE 16, 32 & 64 oint garbage mates from PAul Crisp
find links here:https://www.digitalzoo.com.au/lunchtime/lunch_docs/related_02_free.htm
& here:https://www.kenstone.net/fcp_homepage/eureka.htmlthese seem better than the apple ones in other ways:
if the shape is regular, but moving, you can make a mask, then keyframe the placement.i had problems with that, but 8 points is just not enough, so i use these.
cheers,
nick
