Activity Forums Apple Motion traveling glow on thin line
  • traveling glow on thin line
    Posted by Abbey Benowitz on October 5, 2010 at 9:30 pm
    Does any one know how to make a traveling glow on thin line? I was thinking it might be accomplished by making a duplicate behind the original line and applying the glow to that with a keyframed traveling gradient mask, but I thought there might be an easier way.
    Stephen Smith replied 15 years, 11 months ago 2 Members · 3 Replies
  • Stephen Smith
    October 5, 2010 at 10:56 pm
    Do you want the thin line to animate or just the glow….or both?
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Abbey Benowitz
    October 6, 2010 at 1:04 pm
    Hi Stephen,
    I’d like the glow to animate or travel down the line in a smooth way. The line itself can stay still. I know I’ve seen this effect many times, and am hoping to be able to do it in Motion. Thanks for any suggestions.
  • Stephen Smith
    October 6, 2010 at 4:49 pm
    In this case I think the easiest thing to do is to create a bezier line below the other line. Or if your current line is already a bezier or b-spline line or something duplicate it. Change its color to a yellowish color. Make sure you are working with the shapes outline and not the fill in the Shape tab. Add a Write On behavior. That will animate the line so it writes onto the screen. You can add a Gaussian blur to the line to blur it or set the Brush Type to Airbrush to give it a glowy feel. That is one option. Hope I made sense and best of luck.
    Stephen Smith
