Activity Forums Adobe After Effects Trapcode Soundkeys problem with output Keyframs
  • Trapcode Soundkeys problem with output Keyframs
    Posted by Francisco Castro on April 4, 2013 at 12:42 pm
    I am trying to link my audio to soundkeys to generate keyframes from the beats. I was looking through a RedGiant tutorial and was following exactly what Harry was doing but I can’t seem to generate values for my output keyframes. The keyframes are there but there are no values. The outputs are stuck at 0.
    Please help. Thanks!
    Umbalakada Wattakka replied 9 years, 10 months ago 6 Members · 8 Replies
  • 8 Replies
  • John Cuevas
    April 4, 2013 at 4:58 pm
    Did you choose the right audio layer, by choosing the Audio Layer pulldown and setting it to the correct layer?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Francisco Castro
    April 4, 2013 at 10:16 pm
    Yes I know I hve the correct layer selected and I can even see the bars move as I scrub. When I generate the key frames on the three output ranges there is no values for the keyframes. They’re all 0
  • John Cuevas
    April 5, 2013 at 1:12 am
    Have you tried using soundkeys with a different audio layer? Has soundkeys worked for you before?
    Otherwise if you want to save the project with the audio, collect it and zip it, you could upload it here(last icon in the reply dialogue), I’d take a look and see if it works for me.
    Thinkck.com
  • Caleb Spillyards
    July 3, 2013 at 9:09 am
    was this ever resolved?? I’m having the exact same problem
  • René Andritsch
    August 19, 2013 at 2:09 pm
    Hi, if you’re still looking for an answer to the soundkey problem have a look at trapcode.com – https://www.trapcode.com/forum/post/2157026
    All the best, René
  • Joel Mertz
    September 26, 2013 at 7:13 pm
    Thank you for this link. I was having the same problem as well. It appears that this is an “intermittent bug” related to Adobe CC. Hopefully a patch will come out soon.
    [ j o e l m e r t z ]
    video : design : art : photography
    w: joelmertz.net
    e: joel@joelmertz.net
    a: Dallas, TX
    m: 503.419.7765
  • René Andritsch
    October 9, 2014 at 8:23 pm
    There is a maintenance release for Sound Keys (v 1.2.3) which fixes the zero output issue as posted by Peder Norrby on trapcode.com September 17.
    https://www.trapcode.com/journal/2014/9/17/maintenance-release.html
  • Umbalakada Wattakka
    November 10, 2016 at 4:43 pm
    Download and install the 13.5.1 bug-fix update.
    Here is the link – https://sathutu.com/2016/11/10/after_effect_cc_2015_bug_fix_update_download_free_offline/
    If it failed in the first attempt, try again.
    Patch your After Effects installation using adobe.snr.patch.exe after the update.
    It’s working. 100% Sure.
