Activity › Forums › Adobe After Effects › Trapcode sound keys – equalizer bar
  • Michael Szalapski
    April 28, 2014 at 3:56 pm
    You could use the built-in Generate>Audio Spectrum or Generate>Audio Waveform effects and skip Sound Keys entirely.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Bas V breugel
    April 29, 2014 at 7:38 am
    Thanks Michael, that I didn’t think about.
    The equaliser bar, I made as following, make a solid about 50 pixels width and 300 pixels high.
    Drag the anchor point to the bottum of the bar, and then pickwhip the scale to the output of your sound keys layer. Then copy paste this
    temp = thisComp.layer("soundkeys").effect("Sound Keys")("Output 1");
    [value[0], temp, value[0]]
    over the expression code.
    As a bonus I’ve made a copy of the solid, deleted all the expressions so the solid without animation, added a gradient layers style (red-orange-green) and used that as a mask for the animated sound bar below it.
