Activity Forums Adobe After Effects Trapcode shine loop Fractal noise
  • Graham Quince
    October 11, 2024 at 10:03 am
    Maybe Trapcode Shine’s fractal noise isn’t based on a loopable value (is this something you know should be there?).
    Looking at the available properties, Evolution speed is probably the closest equivalent. So you could set keyframes and then add an expression like:
    loopOut(“cycle”);
    Which would get your keyframes to repeat, or you could go for:
    loopOut(“pingpong”);
    Which would see the speed bounce between your two keyframe values, or lastly:
    loopOut(“continue”);
    Which keeps the value increasing, but by moving the keyframes along the timeline lets you set the speed.
  • Ivaylo Georgiev
    October 11, 2024 at 4:18 pm
    I don’t have any keyframes
  • Graham Quince
    October 12, 2024 at 11:47 am
    But you can set keyframes for it. The stopwatch is right there
