Activity Forums Adobe After Effects Trapcode Particules
  • Trapcode Particules
    Posted by Gon Perdigao on June 26, 2008 at 11:28 am
    Hi there i’m working with trapcode particules, and i parent the x,y,z to a null, and animated the null, the problem is that the path that the particle make’s does not follow the path of the null in the bezier points, it make some wierd line curves, i try to make the bezie lines bigger, but no luck, cause the curvee lines of the particles are still there, here is a print screen:
    Free Image Hosting at www.ImageShack.us
    QuickPost Quickpost this image to Myspace, Digg, Facebook, and others!
    Peter Van der zee replied 18 years, 2 months ago 2 Members · 1 Reply
  • Peter Van der zee
    June 27, 2008 at 12:30 pm
    I normally have it follow a light (pointlight renamed as emitterX)
    and in particular say the emitter is the light.
    It creates nice round curves following the exact path you program for the light…
    http://www.zeemotion.com
