Activity Forums Adobe After Effects trapcode Particular’s camera
  • trapcode Particular’s camera
    Posted by Manny Rellesiva on June 28, 2007 at 1:32 am
    Is there an option/setting in Trapcode Particular where you can use the composition’s camera? or Particular would automatically use the composition’s camera?
    Darby Edelen replied 19 years, 2 months ago 3 Members · 3 Replies
  • Darby Edelen
    June 28, 2007 at 3:50 am
    Particular automatically uses the composition’s active camera.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Steve Roberts
    June 28, 2007 at 12:51 pm
    By the way, you should *create* a camera in the comp manually — don’t use the comp’s default (not really there) camera, which you really can’t control.
  • Darby Edelen
    June 28, 2007 at 2:17 pm
    I should add to that that Particular should be applied on a 2D layer, it handles the 3D internally and if you put it on a 3D layer you’ll end up with the post-card-in-space look. I believe AE warns you of this, but I thought I’d reiterate it =)
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
