Activity Forums Adobe After Effects Trapcode Particular with AE 2015 (new update)
  • Trapcode Particular with AE 2015 (new update)
    Posted by William Saviola on June 21, 2015 at 8:31 pm
    Since the latest AE update I have suddenly found that when I apply particular to a layer and change the opacity over life to fade on and off nothing changes. It just comes on linearly. The same applies to when I change the size over life
    When i tried exactly the same settings on the first version of AE CC the particle faded on and off correctly without a problem.
    I then saved the project file from the original AE CC and opened it in the latest version of AE 2015 and the particles faded on and off but when i tried to change it back to the default settings it did not change and continued to fade on and off.
    I am using particular 2.2.2
    Is anyone else having this issue?
    Ling Talfi replied 10 years, 8 months ago 4 Members · 6 Replies
  • Xander Hugh
    June 22, 2015 at 2:22 am
    Are you applying to an adjustment layer?
    Always best to apply to a black layer and then add/screen/overlay it, but I expect you already know that
  • William Saviola
    June 22, 2015 at 9:15 am
    Yes of course to a Black solid.
    My work computer has version trapcode 2.2.3 and my work machine has 2.2.2 and it is doing the same thing.
    I just tried it on another machine at work which has CS6 and it works fine.
    Has something suddenly changed that i don’t know about since the latest upgrade for AE?
  • Xander Hugh
    June 22, 2015 at 9:40 am
    That’s an odd response to someone trying to help you?
    Precomp the offending layer.
  • William Saviola
    June 22, 2015 at 11:02 am
    I fixed it
    I just went on to the Red Giant site and downloaded Trapcode suite again and in the installation it had after effects 2015 now in the instal which fixed it.
  • Olaf Tischbier
    July 1, 2015 at 3:31 pm
    Thanks for posting your fix. I have the same problem, going to try your solution.
  • Ling Talfi
    December 4, 2015 at 8:55 am
    Same problem here, I have to relaunch after effects 2015 to see the changes.
