Activity Forums Adobe After Effects Trapcode Particular stops responding to camera when nested.
  • Trapcode Particular stops responding to camera when nested.
    Posted by Eoin Ryan on May 19, 2011 at 12:35 pm
    Hello,
    I’m having a problem with Pre-comping Trapcode Particular. I have a nice 3D spiral path along which my particles are flowing, and a camera which moves through the centre of the spiral. All of this works fine and dandy in it’s own comp, but when I pre-comp the motion path and particle layer they stop responding to the camera. I have tried it with and without collapse transformations, and as a 3D layer but to no avail.
    I want to Pre-comp so I can rotate it and have multiple instances of the spiral.
    It’s prob something very obvious, can anyone help?
    Walter Soyka replied 15 years, 3 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    May 19, 2011 at 12:59 pm
    If you precomp then it will not work- Particular needs to be in the same comp as the camera. What you can do is to have a Light set as an Emitter to generate the particles and follow the path. Then you can just duplicate the light and offset it to get multiple instances of the spiral you have created.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Eoin Ryan
    May 19, 2011 at 1:33 pm
    Thanks ted, that works for multiple instances, but only ones that move in the same direction, I was hoping to pre-comp it so I could flip it and have the two spirals moving in opposite directions. Any idea how I could do that without having to draw another path?
  • Walter Soyka
    May 19, 2011 at 1:51 pm
    [Eoin Ryan] “Thanks ted, that works for multiple instances, but only ones that move in the same direction, I was hoping to pre-comp it so I could flip it and have the two spirals moving in opposite directions. Any idea how I could do that without having to draw another path?”
    You could parent one of the lights/emitters to a 3D null, then adjust the null’s orientation.
    Walter Soyka
