Activity › Forums › Adobe After Effects › Trapcode Particular Problem
  • Kalleheikki Kannisto
    November 9, 2018 at 10:09 am
    You can keyframe the properties for sure. The property you are adjusting is the birth rate. That doesn’t mean the particles disappear immediate if you adjust it down. They will live for the entire life duration of the particles, which is a different setting. So if the life setting is 3 seconds, you will start to see the difference more clearly after 3 seconds, as the earlier emitted particles die off.
    Senior Graphic Designer
  • Bradley Kus
    November 9, 2018 at 9:23 pm
    Ahh thanks for clearing that up, did not realize that and was just stuck on the fact that it would only change if the value wasn’t being keyframed. Thanks again.
