Activity Forums Adobe After Effects Trapcode Particular or Form Numeric Reveal
  • John Cuevas
    February 13, 2015 at 2:43 pm
    What exactly are you trying to do? You didn’t really explain what you want to accomplish.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Min Kim
    February 13, 2015 at 5:57 pm
    I basically want to do the same thing; image reveal with particles of numbers. Numbers flying in to form the image. I have found one solution using trapcode form, but the numbers don’t fly-in to the image in the way they do in the reference image.
  • John Cuevas
    February 13, 2015 at 6:27 pm
    this is a little hard to follow, but check out this tutorial using card dance, you might be able to modify it to create your effect. Ayato Text Mosiac
    Thinkck.com
  • John Cuevas
    February 16, 2015 at 2:25 pm
    Spent an hour looking for an old file I did years ago(no joy), where I broke a person apart like that using words, rather than binary code. Basically the trick was to choose the layer as your source in emitter and use custom particles. So try starting there.
    Thinkck.com
  • Min Kim
    February 18, 2015 at 9:15 pm
    Thank you very very much for your help!
    It definitely works.
