Activity Forums Adobe After Effects Trapcode particular (morphing one text into other)
  • Trapcode particular (morphing one text into other)
    Posted by Ambar Singh on December 16, 2014 at 5:33 am
    Thank you for your help. See this awesome clip –
    https://www.youtube.com/watch?v=Rr1oCf0JRbs
    watch at :20sec and :33sec (words break up into little square particles and at :33 they break apart, float and form another words).
    Is it something that can be done through trapcode particular. or if not which tool can help ? would you suggest any direction ?
    Michael Szalapski replied 11 years, 9 months ago 3 Members · 3 Replies
  • John Cuevas
    December 16, 2014 at 5:49 pm
    Trapcode Form is probably easier for something like that, but Particular can be used.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Ambar Singh
    December 17, 2014 at 1:28 am
    Thank you John for your help but I don’t know how to do it in particular or form, could you please suggest any tutorial or way to do it ?
  • Michael Szalapski
    December 17, 2014 at 9:38 pm
    Follow most any “text to sand” tutorial and do it for both words. Precompose one of those and time remap it so that it’s time-reversed. Then fade the two together. (That’s one way.)
    If you use Form to break it apart with your text in a precomp, you could simply change the precomp and then undo all your text breaking apart business. Again, there are several tutorials out there for using Form like this.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
