Activity Forums Adobe After Effects Trapcode Particular Flickering
  • Trapcode Particular Flickering
    Posted by Gene Gemperline on May 1, 2008 at 7:23 pm
    So I’m having some frustrations with Particular. I’ve got a four-layered particle explosion.
    1st layer is a 2.5D butterfly.
    2nd layer is a colored sphere.
    3rd layer is an alpha matted streamer (aux emitter).
    4th layer is a smoke thing
    I’m gettins some weird flickering on the spheres and butterflies. Here’s a youtube link. It’s low-res, but you can see the problem at around 6 seconds in on one of the bottom butterflies. Not all of them flicker, mind you – just a couple; but in full-res it’s definately noticeable.
    https://www.youtube.com/watch?v=gXRX6rZXaFo
    Has anybody else run into this? Any advice would be much appreciated.
    Gene Gemperline replied 18 years, 3 months ago 2 Members · 2 Replies
  • Jeremy Fabiano
    May 1, 2008 at 7:39 pm
    Maybe it’s me being tired, or youtube being youtube – but I don’t see any flickering 🙁
    Also that’s very nicely done i might add – good job 😉
  • Gene Gemperline
    May 1, 2008 at 8:04 pm
    Thank you.
    Yeah – it probably is YouTube being YouTube. It’s hard to see, but if you look at the red butterfly on the bottom (it’s bigger) between 5 and 7 seconds, you can see the luma kind of drop out for a frame or two. It’s very frustrating.
    But I’m glad you liked my work.
