Activity Forums Adobe After Effects Trapcode Particular – different particles per emitter?
  • Trapcode Particular – different particles per emitter?
    Posted by David Gudelius on February 6, 2008 at 4:30 pm
    Hi there,
    I’ve got a question: is it possible to tell Particular that it should take more than one layer as a particle?
    I need up to 60 different particles (textlayers in my case) being emitted… and I don’t want to place 60 emitters in the scene, setting up all of them differently.
    Is there a solution for my issue with Particular, or would you recommend another 3D particle system?
    Thanks in advance!
    David Gudelius replied 18 years, 7 months ago 3 Members · 4 Replies
  • Jeremy Allen
    February 6, 2008 at 5:42 pm
    I’m not sure if this is exactly what you want, but it might get you close..
    You can set up a precomp with each text “particle” taking up one frame. For example, frame 1 would be “T”. Frame 2 would be “E”… etc..
    add particular to a solid and then:
    Particle > particle type > custom
    layer > your text precomp
    time sampling > random, still frame
    So every particle that comes out will be a random frame from your precomp.
    I hope I’ve explained this well and it works for you..
    Anybody else?
  • Steve Roberts
    February 6, 2008 at 6:06 pm
    That would be my solution.
  • David Gudelius
    February 6, 2008 at 9:14 pm
    Thank you very much,
    I’m gonna test this directly tomorrow and report if it worked.
    Thanks again! You might have saved me from working too much hours tomorrow. 🙂
  • David Gudelius
    February 7, 2008 at 3:52 pm
    All worked fine – thanks for that, guys!
    I wish that someday Particular would be able to orientate the particles according to the 3D camera, too… REAL 3D particles.
