Trapcode Particular Animate Motion Path
Hello,
Is there a way to animate the “Motion Path” Particular uses or blend it from from “Motion Path A” to “Motion Path B”?
Goal: Particular “liquid” traveling inside hose path as the hose path changes shape over time.
Or, put another way… I want to
1) move “liquid” spheres along a custom “hose” path shape, and then
2) change the shape of the hose path over time.I’ve figured out step 1. I created a light and animated that along the custom path I’m using for the hose path shape layer. I then set the Motion Path (in Physics->Air) to be that light. I’ve got everything flowing nicely along the hose.
However, I can’t seem to figure out step 2. Is there a way (with Particular) to animate the shape of the “Motion Path” reference in the Physics->Air section?
I could probably create a C4D solution for this but my client needs edibility within AE (CS6!).
Any suggestions are much appreciated.
Jonathan
