Activity Forums Adobe After Effects Trapcode Particular and Spin Amplitude/Affect Position not affect z-dimension
  • Trapcode Particular and Spin Amplitude/Affect Position not affect z-dimension
    Posted by Sarah Schela on December 14, 2012 at 7:08 am
    Hello folks,
    is there any way (i.e. expressions) to get the Trapcode Particular not to affect the z-dimension when applying Spin Amplitude or Affect Posiiton?
    I have particles (leafes) which overlap and flicker, when wiggling them with the affect position/spin amplitude parameter)
    any help appreciated!!
    thanks!
    Sarah Schela replied 13 years, 5 months ago 2 Members · 2 Replies
  • Darby Edelen
    December 15, 2012 at 1:00 am
    There is no way to prevent Spin or Turbulence from changing your particles Z position. One thing you could try would be to reduce the number of particles being generated and generate them in a shallow area close to the camera. Then create another layer (or two) below the first and move the shallow area farther from the camera. The particles from the different systems would never intersect.
    Potential problems with this are 1) pain in the butt 2) possible perspective mismatch if the systems are close together (the particles should be overlapping but aren’t).
    Darby Edelen
  • Sarah Schela
    March 29, 2013 at 8:29 pm
    I am very thankful for your reply. I’m sorry it took me so long to answer!
    Your suggestion is quite the thing I tried out I think.
    I ended up using particular leafes for bg and replace the ones in the fg with photo material which looks much more natural. I wiggle each layer of leafes individually.. thousands of layers, parents and expressions.
