Activity Forums Adobe After Effects Trapcode MIR Texturing.
  • Trapcode MIR Texturing.
    Posted by George Rupp on May 19, 2018 at 1:17 pm
    Hi there,
    So i’m very new to this plugin and I’ve been watching a tutorial online where someone applied a texture that has an alpha channel to a MIR object (the texture was a precomposed fractal noise layer with a mask feathering the border).
    From what I can see it applied this alpha to the MIR object and subsequently applied the feather (unless i’m mistaking something else for transparency?)
    However when I attempt the same it replaces the alpha with black (seen here https://imgur.com/AUCYYA0). I’ve gone through every possible setting including blending modes, shaders etc, and I cannot for the life of me figure out why.
    Any help would be appreciated!
    (In case you need more context, Im trying to make a large tube that fades out towards the end so that whatever solid layer I’ve got behind it gradually gets blended in. )
    View post on imgur.com
    Steve Bentley replied 8 years, 4 months ago 2 Members · 1 Reply
  • Steve Bentley
    May 19, 2018 at 9:40 pm
    I know there is an issue with the Form plug in with alphas and that may be the same with MIR. I think this used to work but something changed. You could search the Trapcode forum on the cow because there was a big discussion about this withing the last month.
