Activity Forums Adobe After Effects Trapcode Form
  • Trapcode Form
    Posted by Nina Bjer on May 13, 2011 at 4:04 pm
    I’m learning trapcodes form and have made some forms I like but want them to move very very slowly. Can I do that? I flow evolution seems to control this, but I can’t make it slower than it is from the beginning here it seems. Does anyone know how to do this?
    Thanks in advance!
    Kind regards
    Nina
    Nina
    Nina Bjer replied 15 years, 4 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    May 13, 2011 at 6:01 pm
    One quick work around is to work at a higher frame rate, render and then bring in a standard frame rate comp- you can get slow motion that way. If you need to speed up after, you can time remap.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Nina Bjer
    May 13, 2011 at 8:13 pm
    Aha, yes that’s an idea! Thank you! 🙂 But isn’t there a place in the plugin where I can control the speed of the movement of a form? I want the form to be almost still at times. Otherwise I’ll do what you suggested! 🙂
    Nina
