Activity Forums Adobe After Effects Trapcode Form – Particles X,Y,Z are greyed out ! Why ?
  • Jim Scott
    April 2, 2016 at 3:57 pm
    In OBJ mode the placement and number of particles is determined by the vertices in your model, and not by the Particles settings in the Base Form. You can thin them out by skipping vertices using the Skip Vertex option in the OBJ Settings, but to otherwise change the number you would need to redo your model with more or less vertices.
  • Josh Rod
    April 2, 2016 at 4:26 pm
    🙂 Thanks Jim
