Activity › Forums › Adobe After Effects › Trapcode Form. Need advice to make seamless/smooth animation
  • Trapcode Form. Need advice to make seamless/smooth animation
    Posted by Emil Dahl on August 31, 2020 at 5:47 pm
    Hi!
    I am currently working on an animation in Red Giants Trapcode Form plugin and I’m having trouble getting a smooth animation without bad looking “stops”.
    I primarily believe it’s a keyframes/easing problem, but I can’t pindown exactly where the problem is. It’s possible that it’s a technique I don’t know of or an expression that can solve my problems.
    The project is very light so I can send it easily – I believe its possible to see the animation even without having bought the plugin you just get a watermark.
    The “design” and duration of the animation needs to stay around +/- 10% of what I currently have.
    Project File:
    14293_forside1.aep.zip
    Vimeo link to the current video:
    https://vimeo.com/453372130/35aa961fcf
    I hope someone can help ☺
    Kind regards
    Emil
    Emil Dahl replied 6 years ago 2 Members · 2 Replies
  • Martin Schmidt
    September 1, 2020 at 9:59 am
    Dear Emil
    Thanks for your Post on the CreativeCow Forum!
    As I am not very good with expressions and I had no clue how to make the viodeo smoother, I downloaded the project file you provided and changed the Easings in Comp 7.
    I hope that was the right comp.
    Anyways, here is your Project back as a zip:
    14298_forside1.aep.zip
    And also I have rendered it out once so you could see it, here is the vimeo link:
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    https://vimeo.com/453592179/41871c1804
    Greetings
    Martin
  • Emil Dahl
    September 2, 2020 at 9:29 am
    Thanks a lot for the try! I still want the start and other parts smoothed some more so I will take a look at your easings and see if I can learn something to fix the start especially.
    And research some expressions to see if they can make it better
