Activity Forums Adobe After Effects Trapcode Form – custom particle/colour map problem
  • Trapcode Form – custom particle/colour map problem
    Posted by Rob Nield on March 22, 2009 at 11:40 am
    I’m trying to use Trapcode Form to smash an image into little mosaic pieces but I can’t seem to get it to work the way I want it to. The image has been cut out in photoshop and I’m using a separate Form layer to colour map it. Trouble is each individual particle assumes the shape of the outline of the image. I would use the custom particle parameter to fix this but it turns out you can have either a custom colour map or a custom particle – not both. Am I doing something wrong – or is the Form plugin not advanced enough to deal with both custom particles and colour maps at the same time?
    Peder Norrby replied 17 years, 5 months ago 2 Members · 1 Reply
  • Peder Norrby
    March 23, 2009 at 11:06 am
    It sounds like you want Form to split your image spatially, it cannot do that. But there are some plugs that can: Shatter, Card Dance I think..
    The closest you can get in Form is to use a really small sphere particle and the image as Color map over XY. It will be a “disintegration” effect, not shatter.
    Peder Norrby / Trapcode
