Activity Forums Adobe After Effects Trapcode Form – blink bug?
  • Trapcode Form – blink bug?
    Posted by Jamie Bradshaw on April 6, 2010 at 9:44 am
    I just thought I’d share this problem (bug?) I found on Trapcode Form and a workaround I found as I’d hate anyone to tear as much hair out over it as I did.
    Basically I had the Trapcode Form effect on a Shape Layer. I was using a pre-composition as a Custom Particle. For some reason this caused the particles to blink on and off (almost rhythmically).
    I spent ages trying to work out what it could be and then I discovered that if I made sure the visibility of the pre-composition layer was turned on then it fixed it. Obviously I’ve just had to turn the transparency to 0% instead.
    Anyway, like I said, I thought I would just share,
    Jamie
    JimJam•Graphics
    https://www.jimjamgraphics.com/
    Roland R. kahlenberg replied 16 years, 5 months ago 2 Members · 1 Reply
