Activity › Forums › Adobe After Effects › Trapcode 3D stroke
Trapcode 3D stroke
Posted by Jon Hutton on June 21, 2008 at 12:41 amIm trying to use Trapcode 3d stroke to wrap around a cell phone, i am starting a path on the bottom and want it to circle around the cell phone to the top but am having trouble doing this I can make the path but i need it in the z space to move behind the cell phone when it wraps around, it just looks like im drawing on top of the phone
Michael Nadell replied 18 years, 2 months ago 3 Members · 7 Replies -
Bill Kelly
June 21, 2008 at 3:22 amDo you have the phone as a 3D layer? If it’s just 2D that’s your problem. If you do have it as a 3D layer, try moving it forward in Z space.
Jon Hutton
June 21, 2008 at 3:42 amthis is my comp if it helps, im am spiralling the text up around the cell phone to reveal it flipped open and would like a 3d stroke to follow my text around the phone
Jon Hutton
June 21, 2008 at 3:43 amhttps://www.screencast.com/users/denied55/folders/Jing/media/99a0bffd-f4a0-40e8-95e6-a8442d164ba7
sorry there is the link for my screen cap
Bill Kelly
June 22, 2008 at 1:57 amOkay, I saw your screencap. What you need to to is make the path in 3D space. Delete whatever path you have now. Select your 3D Stroke layer in the timeline. Turn it into a 3D layer. Select the pen tool. Change the view to Top View. Make the path go around and behind and then in front of your phone.
Your screencap looks like it’s CS3 you’re running. Here’s a CS3 project file with what I’m describing.
https://rendertainment.com/3D Stroke around object.zip
Bill Kelly
June 22, 2008 at 1:59 amHighlight the whole URL and paste in it your browser. Clicking the link doesn’t work because I didn’t put underscores in the file name instead of spaces.
Michael Nadell
June 22, 2008 at 4:40 amWhat you should do is duplicate your 3d stroke layer (make sure its not in 3d mode)
Put one layer in front of your phone, and one behind.Play with the 3d stroke camera Z clipping settings (ie. leave Z clip front at zero and set the Z clip back to a smaller number than the default (try 400 for example))
Note what it does to your stroke…
Once your find a setting that clips your stroke to look like only the parts that would be in front of your phone, take that value and put it into the Z clip front setting of your back layer.
The key is to understand how the Z clip settings effect 3d stroke.
Hopefully that makes sense…
