Activity › Forums › Adobe Premiere Pro › transparent video
transparent video
Posted by Panos Stavroulis on February 20, 2006 at 4:41 pmTransparent video track does not works as in Aeffects(adjustment layer).Does anyone know in steps how it works?REGARDS PANOSS
Panos Stavroulis replied 20 years, 6 months ago 3 Members · 5 Replies -
Theoutsider
February 20, 2006 at 5:30 pmThis has been discussed at length in previous posts. Transparent video is not an adjustment layer and only a small handful of effects work on it.
Carlitos
February 20, 2006 at 5:47 pmTransparent video is no more than an ordinary Alpha Layer.
Imagine a Title layer without titles, that’s what it is.
Panos Stavroulis
February 22, 2006 at 1:55 pmHi there thanks for the replys.So how the tracks under the transparent track have the result of applying an effect in transparent track?Regards panoss
Carlitos
February 22, 2006 at 11:41 pmSo how the tracks under the transparent track have the result of applying an effect in transparent track.
.- There is NO results or changes on the layers under the transparent track, it is NOT an adjustment layer.
It’s not much you can apply in the invisible layer and, repeat, there is NO effect, variation or change on the layer(s) underneath.
Some GENERATOR-type effects, like Knoll lighting effects, particles and, of course, Titles.
It is a simple. common and ordinary alpha layer, nothing special.
So, basically, it’s not a feature to jump out of joy.
Panos Stavroulis
February 23, 2006 at 1:38 pmCARL many thanks for your feedback .I was confuse because Aanarav Sareen wrote this on his tytorial…
‘Just apply an effect to the transparent video track and the results from the effect will automatically be apparent on all other underlying tracks’.REGARDS PANOSS
