Activity › Forums › Adobe After Effects › Transparent Stroke
Transparent Stroke
Posted by Mr Scholz on September 15, 2016 at 12:39 amHow is it possible to create a transaprent stroke around an object?
____ Layer 1 with Stroke
____ Layer 2 (invinsible at the Stoke of Layer 1 )
____ Layer 2 (vinsible at the Stroke of Layer 1)
Kalleheikki Kannisto replied 10 years ago 3 Members · 7 Replies -
Greg Gesch
September 15, 2016 at 12:55 amHi Marcel, I’m confused about what you want to do. If it is transparent then you cannot see that it is there, so whatever is behind it will show through whether it is there or not. Perhaps you can give an example or explain more clearly?
Mr Scholz
September 15, 2016 at 1:01 amI have 3 Layers in the stroke of my First layer which is on the top i want to see the third layer
So the stroke of my First layer would make the second layer “invinsible” and the third layer shine through
Greg Gesch
September 15, 2016 at 1:12 amDo you mean the Stroke effect, or the stroke setting on a shape or text layer? Is the stroke moving so as to reveal the 3rd layer bit by bit, or is it fading out?
Mr Scholz
September 15, 2016 at 1:52 amI use a layerstyle stroke on a Picture …
I dont know if a stroke is the best Way but what i want to do ist like a gap between my Picture ( a Logo ) and the Background but complet around like a stroke
Mr Scholz
September 15, 2016 at 7:15 amIt should Look like that this but in after effects https://forums.adobe.com/thread/1907798
Mr Scholz
September 15, 2016 at 7:37 amI could also copy the layer gif it a stroke an then is my question how i Can Show the layer under that on the places where Not my stroke layer is
September 15, 2016 at 7:55 amThe trick is using the text with the stroke as an alpha inverted track matte for the layer you want to add the transparency to. If there are several layers yo want to apply it to, precompose them first.
10560_knockouttextoutlines.aep.zip
Senior Graphic Designer
