Activity Forums Adobe After Effects transparent solid?
  • transparent solid?
    Posted by Ian on August 9, 2005 at 2:52 am
    Hello everyone. I’m trying to create a thin, vertical randomly-moving solid over a larger non-moving stationary solid.
    How do I make the moving solid transparent?… that is, as it moves, the area directly under it is transparent?
    Thanks in advance for your help.
    Todd Schmidt replied 21 years, 1 month ago 3 Members · 3 Replies
  • Michael Munkittrick
    August 9, 2005 at 3:50 am
    A layer mask would set as little as a single pixel width line apart from the rest of the solid, or you could always create your lines in Photoshop and import them as a composition instead of a still to keep the transparency by turning off the background layer.
    Michael Munkittrick
    Managing Creative Director
    Evolve Media Solutions
    Forum COWmunity leader for:
    Sony DV
    Magic Bullet
  • Ian
    August 9, 2005 at 4:04 am
    THANKS MM!!
  • Todd Schmidt
    August 12, 2005 at 6:49 am
    Well, I sort of know what your asking. If you have the visual in mind, either mask that solid in a seperatapt comp and keyframe it in any way you see fit, or if you want a certain solid (logo, etc.) make it in photoshop and do that. I hope I have grassped what you needed correctly.
    T
