Activity Forums Adobe Photoshop Transparent PS background for text doc.
  • Transparent PS background for text doc.
    Posted by Gary Madison on January 7, 2009 at 12:01 am
    Hi
    How do I create a PS text doc with a transparent background.
    I would like only the text to show and use it for titles and sub=titles overlayed in FCP….
    gary
    Gary Madison replied 17 years, 8 months ago 2 Members · 2 Replies
  • Nathan Grealish
    January 7, 2009 at 9:27 pm
    The way I have done anything with a transparent background would be to first make the graphic and make sure you can see the gray and white squares signifying that it is indeed background.
    After you see that, go to File > Save As.
    Name your file whatever you want and right below the File name box, click on the drop down list and chose “CompuServe GIF (*.GIF)”.
    Click “Save” then on the next window you can keep the Palette to Exact, Forced: Web (or whatever colors you need)and make sure “Transparency” is checked off. Matte can stay at none.
    Click “OK” and it is saved with a transparent background.
    I hope this was what you were looking for. It should be able to import into any program you need without a background.
    Always Start with the End in Mind
  • Gary Madison
    January 14, 2009 at 7:07 am
    Hi
    In the current version of Ps an in my older version Save as Compuser GIF is not an option in the drop down menu’s either on…
    Thank you so much for the attempt.
    Only the best to you
    gary
