Activity Forums Cinematography Transparent Objects – Green Screen
  • Transparent Objects – Green Screen
    Posted by Fred Roberts on May 24, 2012 at 5:38 am
    Hello to all-
    Given the inherent difficulty of searching for the terms “green screen” and “transparent”, I am hoping someone will have some sound advice for a shoot I’ll be doing this Friday.
    I need to shoot a protective helmet face shield (clear plastic) in front of a green screen. I have no choice but to use the green screen, as the other 95% of the subject is not transparent, and the client needs the ability to be flexible with the background replacement.
    This doesn’t seem theoretically possible, as the green light will most likely pass through the plastic. So I appeal to anyone with experience or knowledge about this situation that can guide me a bit.
    Thank you very much.
    Fred Roberts replied 14 years, 3 months ago 3 Members · 3 Replies
  • Mark Suszko
    May 24, 2012 at 5:16 pm
    Try lining the back of the transparent object with some white paper.
    Then adjust opacity and blending mode after the key is established. Just a guess.
    Or use Ultimate.
  • Emre Tufekcioglu
    May 24, 2012 at 5:31 pm
    Using After Effects (keylight) you can key through transparent objects and keep their detail on them. Based on the backdrop you are using in AE you can recomposite the textures or reflections back into the glass.
    Here is a tutorial on how to keep textures of transparent subject in the keying detail:
    https://www.videocopilot.net/tutorials/advanced_soft_keying/
    Hope this helps
  • Fred Roberts
    May 26, 2012 at 5:14 pm
    Thanks I think that will probably be helpful.
