Activity Forums Adobe After Effects Transparent moving graphic
  • Transparent moving graphic
    Posted by Peter_student on February 24, 2007 at 8:51 am
    I have created an animated watermark in AE to be put over my footage in Premiere..my problem is that when i export from AE the watermark retains the black background thus making it impossible to impose on my footage in Premiere.. its probably something as simple as un checking a box that says transparent background.. i just cant find it!
    Thanks in advance for your help
    ps- its been so long I’ve forgotten how to extend my time line to allow for more frames to create longer graphics.. any help?
    Peter_student replied 19 years, 6 months ago 3 Members · 3 Replies
  • Graham Quince
    February 24, 2007 at 9:42 am
    When you render your logo footage, make sure you alter the RGB setting to RGB+, that will export an alpha channel as well.
    To extend your timeline, go to Composition > Composition Settings and change the length of your comp.
    Hope both of those help
    Graham
    https://www.quinceweb.com – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • Erik Pontius
    February 24, 2007 at 4:56 pm
    To expand the previous post a little. You’ll need to find a codec for your rendered video that also supports an alpha channel (DV AVI uses compression and will not allow an alpha channel) and also is compatible with Premiere. You best option might be for an uncompressed AVI, choosing “RGB + Alpha” and “straight” matte.
    Premiere should be able to import this footage and recognize the alpha channel thus making your transparent areas transparent…
    Erik
  • Peter_student
    February 25, 2007 at 6:03 am
    Thanks gentlemen for the help..I’ve opted to just import footage into AE! Thanks very much
