Transparent Key in BCC 5.0.1
Posted by Matthew Lopes on November 16, 2007 at 2:39 pmI’m having the same problem. Perfect key until rendered out then its kind of transparent. Need help!
Intel Mac, FCP 6.0.1, BCC 5.0.1
Jeremy Garchow replied 18 years, 10 months ago 3 Members · 5 Replies -
Vik Narayan
November 16, 2007 at 8:50 pmMatthew,
Can you give a little more details about your situation. Are you using just a chroma key, or are you using any additional matte contol plugins? Have you checked the key against the checkerboard background? – this is a good way to see if there is transparency in the ‘opaque’ areas of the frame.
Jeremy Garchow
November 16, 2007 at 9:05 pmOh no, this is not a bad kay, this is a bug. After rendering, it appears as if a transfer mode is applied to the key subject.
https://forums.creativecow.net/thread/15/857204
Jeremy
Matthew Lopes
November 20, 2007 at 3:42 pmI went back to using BCC 4 and it worked perfectly but render time was much slower. I hope this gets addressed quickly.
