Activity › Forums › Adobe After Effects › Transparent handwritten text reveal
  • Transparent handwritten text reveal
    Posted by Michael Ward on July 23, 2020 at 5:11 am
    G’day,
    I am wanting to create a text title over a looped animated video. The text is to be a handwritten reveal as though someone is writing the text.
    I’ve found lots of tutes and in a way they all work, however the original font that I used to trace the mask path remains. So for example, there is my word visible already prior to the reveal animation (which works fine).
    How can i have it so the text is invisible, then it reveals.
    If I was working on a static solid background, easy. But I’m on a animated video background.
    Thanks in advance.
    John Cuevas replied 6 years, 2 months ago 2 Members · 1 Reply
  • John Cuevas
    July 23, 2020 at 5:47 pm
    What technique/effect are you using to reveal your word? If it’s ‘write-on’, You need to change the paint style to “Reveal Original Image.”
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
