Activity › Forums › Apple Final Cut Pro Legacy › Transparent (cutout) Titles in FCP7
  • Transparent (cutout) Titles in FCP7
    Posted by Jd Christie on August 9, 2010 at 2:39 pm
    I know I wont use the correct terminology here, because if I knew the terminology my searches would have been more productive.
    I am looking for instructions or a plug-in for FCP7 that will allow me to create titles that are “cutout” of a solid foreground, allowing the video behind to show through the text. I have seen this effect a few times before, but cannot find an example at the moment.
    Any help is greatly appreciated.
    JD
    Jd Christie replied 16 years, 1 month ago 2 Members · 2 Replies
  • Rafael Amador
    August 9, 2010 at 5:55 pm
    – Put an image in layer 1 and another in layer 3.
    – Put a text generator in layer 2.
    – In the layer 2 set the Composite Mode: Travel Matte Alpha
    The text will cut the layer 3 picture on top of the layer 1.
    Look for the tutorials of Walter Biscardi on Travel mattes to learn more.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Jd Christie
    August 12, 2010 at 12:39 am
    Thank you Rafael! This is exactly what I needed. Here’s my finished product thanks to your help:
    https://vimeo.com/14058486
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
