Transparent Bottle Rendering
Hi guys,
I’m having a few issues with rendering a transparent bottle and I’m hoping you can help me out.
Here’s the effect I’m going for: (transparent bottle placed onto a dark background)
This was rendered in 3DS Max using Vray, however I’m using Cinema 4D and their standard render engine.
The bottle needs to be composited onto the background in post as the colour & brightness of it may need changing.
I figure the way to do this is to render the bottle with an object buffer, however when I do that, I don’t get the transparency I’d like:
I’m sure that the lighting setup and background within the scene are crucial to getting this looking the way I want it, but I don’t work with transparency all that often and so I can’t seem to figure this out. At the moment, I have an off-white background with some lights & a single soft-box (using a dark background subsequently darkens the entire bottle). The bottle has to retain that bright, reflective and realistic look whilst still being able to switch out the dark background in After Effects. The stupid thing is, I’m sure I’ve managed something like this in the past, but I’ve been trying to rack my brain around it for the past hour or 2 and I’m getting nowhere.
Here are my material settings:
https://gyazo.com/d893e3f7fb361c25d975fb10422cfefa
https://gyazo.com/a7b9cb0be548d7db3cfb6348e748e70a
And a quick snap of the scene:
https://gyazo.com/0017b64600fdada1cc4cc02618b67626If you have any advice on how to approach this, it would be massively appreciated.
Thanks very much!
– Jack
