Activity Forums Apple Final Cut Pro Transparent bar behind lower third text
  • Transparent bar behind lower third text
    Posted by Marc Morel on October 1, 2012 at 2:50 pm
    Good morning all,
    I’m presently subtitling a clip and need a simple transparent black bar behind my lower third white text. How can I achieve this? I’ve tried putting a rectangle “shape” from the Generators/Elements browser but the process is long and difficult to adjust and I don’t see a transparency setting. Please tell me I’m missing something.
    All insights, even RTFM suggestions would be respectfully accepted,
    Marc
    Bill Willins replied 13 years, 11 months ago 4 Members · 5 Replies
  • Bret Williams
    October 1, 2012 at 2:57 pm
    There’s a FM? You can use the rectangle or black solid in the generators. Then in the inspector adjust the opacity, under video. If using a black solid you would also adjust the crop there to taste.
  • Marc Morel
    October 1, 2012 at 3:09 pm
    Thanks Brett. I’m slowly getting there. I think I was just hoping for a magic tick box I had forgotten somewhere that would do that for me.
    Thanks again,
    Marc
  • Bret Williams
    October 1, 2012 at 5:47 pm
    It’s a magic slider I guess.
  • Jari Innanen
    October 2, 2012 at 5:33 am
  • Bill Willins
    October 2, 2012 at 4:19 pm
    Once you get a lower third box and text you like, simply copy and paste when you need to re-use it, then you can go in and readjust type or parameters, this speeds things up. You don’t need to re-create each time.
