Activity › Forums › Boris FX Particle Illusion › Transparent Backgrounds…
  • Transparent Backgrounds…
    Posted by R4mpant on January 24, 2007 at 10:06 pm
    I want to overlay the emitters on to a video, but my problem is i can’t load the video files into PI SE, becuase it simply crashes. This Happens with all Fraps files (if you could tell me why i would be very greatful). Is there anyway of making a transparent background, so i can apply the emitters to video, by laying them on a seperate video track, in say vegas? I was also wonding how i can import photoshop images, if you can.
    Thanks, Tobi
    R4mpant replied 19 years, 8 months ago 2 Members · 2 Replies
  • Elvis Deane
    January 24, 2007 at 10:31 pm
    If you render out of pI as a .tga sequence, your particles will have an alpha channel. If its not in the dropdown when you’re choosing a format to render to, you can just type .tga after your file name and it will allow you to save alphas in the Render Settings screen.
    Check out the Frameserver portion of this tutorial as a way that has always worked for me to get clips from Vegas into pI with no hassles.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
  • R4mpant
    January 24, 2007 at 10:58 pm
    Thanks so much, it worked wonderfully.
