Activity Forums Adobe After Effects Transparent background to import into premiere pro – not working
  • Transparent background to import into premiere pro – not working
    Posted by Lillian Fidler on July 7, 2013 at 9:13 pm
    Hi: I want to export an intro with a transparent background and import it into premiere pro. I’ve tried alot of combinations when saving the intro … avi with rgb+alpha and quicktime with different settings (png, animation, etc.)… but everything I try ends up with a black background when imported into premiere pro. I’m using a pc and the latest versions of the software…
    any ideas?
    many thanks.
    Lillian Fidler
    Jillian Productions
    St. John’s, Newfoundland
    Canada
    Jeff Kay replied 13 years, 2 months ago 4 Members · 6 Replies
  • John Cuevas
    July 7, 2013 at 9:47 pm
    No offense intended, but please click the checkerboard under your comp window and verify you have transparency(you don’t know how many times I’ve answered alpha questions when their was no working alpha information).
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Lillian Fidler
    July 7, 2013 at 9:52 pm
    Thanks, yes, I’ve set it to transparency ;.)
    Lillian Fidler
    Jillian Productions
    Canada
  • John Cuevas
    July 7, 2013 at 11:00 pm
    Take one of your renders and re-import it into AE and see if you have an alpha, if you do, the problem lies with your interpretation settings in Premiere
    Thinkck.com
  • Lillian Fidler
    July 8, 2013 at 1:35 am
    Good suggestion, I did import it and it looks fine, has the transparent background. I will look for the settings that may be causing that in Premiere pro. Thanks, that allows me to stop chasing my tail :.)
    Lillian Fidler
    Jillian Productions
    Canada
  • Tero Ahlfors
    July 8, 2013 at 7:00 am
    [Lillian Fidler] “but everything I try ends up with a black background when imported into premiere pro”
    If it has an alpha and it shows a black background then do you actually have anything on a lower video track so it can show that below it? There are no transparency grids in Premiere.
  • Jeff Kay
    July 8, 2013 at 10:28 pm
    Just to test this I exported a quick AE video with alpha. It was exported raw. Output Module “Lossless with Alpha” preset. It worked fine giving the appropriate alpha channel.
    Now working with raw exports can be cumbersome to say the least, so make sure that whatever format you are encoding your export into can appropriately handle an alpha channel.
