Activity › Forums › Adobe After Effects › transparency with lens flare
Brad Schimanski
February 18, 2014 at 1:01 pmfound this on a neighbouring site: works a charm and far easier than some of the options below.
https://www.damonledet.com/2008/06/after-effects-lens-flare-with-transparent-background/Step one: Create a solid and add the lens Flare filter to it, get the lens flare just how you would like it and duplicate the solid.
Step two: Set the bottom solid to use the top solid as a track matte (Luma Matte)That’s it transparent lens flare.
there was a bit more too it but thats all you need.
hope it helps
Brad
