Activity Forums Adobe After Effects transparency question
  • transparency question
    Posted by Steven J casey on April 17, 2006 at 8:47 pm
    Simple question I’m sure…I’m cutting photos into layers in photoshop, sending into ImageReady to export all layers as files. Format is GIF with transparency and trying to bring into AE to do some 3D effects. Once in AE the transparent parts are now white, so I’m missing a setting somewhere for recognizing alpha? I can color key out the white, but this seems a really bad way to go with dozens of photos in the project. Am I just missing a check box somewhere?
    thx
    sjc
    Steven J casey replied 20 years, 5 months ago 3 Members · 4 Replies
  • Mike Clasby
    April 17, 2006 at 9:09 pm
    I never really use GIF’s in AE so I did what you did in Image Ready and get the same problem in AE. It seems like it shouldn’t be a problem, but it is. I think the best solution for you is to take the layered file back into to Photoshop, then Save As a psd file, then import that into AE as a Composition (will have all layers in a composition) or as footage (and you choose a layer).
  • Steven J casey
    April 17, 2006 at 9:12 pm
    Thanks. That seems so obvious now, of course. I edit in Vegas so wasn’t in the mindset to use the PSD file since I’m used to splitting out the layers. Thanks for the fast reply!
    sjc
  • Alon_a
    April 17, 2006 at 10:17 pm
    NEVER use GIF for transparency. It doesn’t have an alpha channel, only a single transparent color, and that’s bad bad bad for aliasing and anything else thas to do with transparency. Always use PSD as suggested above or PNG which is a great format for any situation where you can’t use the original Photoshop layers. Make sure the PNG is set to “millions of colors+” or 32-bit or whatever the app you use calls it and you’ll be good to go.
  • Steven J casey
    April 18, 2006 at 4:10 am
    Another good tip. Thanks!
