Activity Forums Maxon Cinema 4D Transparency map doesn’t follow animation
  • Transparency map doesn’t follow animation
    Posted by Steve Barnier on April 1, 2011 at 7:20 pm
    I’ve applied a texture with a gradient transparency map to an Extrude NURBS object (an arrow shape) which is then animated along a Spline Wrap. The frame where I’ve applied the texture to looks fine, but when I move the NURBS object along the spline the texture doesn’t move with it. At least the transparency map doesn’t. If I turn off the transparency channel I can see that the texture has followed along with the arrow. I’m I doing something wrong or leaving out a step?
    Thanks.
    Steve Barnier replied 15 years, 5 months ago 2 Members · 2 Replies
  • Michael Szalapski
    April 1, 2011 at 9:31 pm
    There’s a stick texture tag you might try.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Steve Barnier
    April 1, 2011 at 11:39 pm
    Actually I tried that. I’ve also applied the texture using “Flat” and “Frontal” and most others. Still won’t work for me.
