Activity › Forums › Adobe Premiere Pro › Transparency Lower Third
Posted by Julia Schmid on May 28, 2011 at 11:35 amI created a lower third with premiere pro cs5. I want to export this lower third to use it in other projects. But how can I do this to save transparency all around the graphic? (i already tried to export but i always get the black backround screen around the lower third)
Julia Schmid replied 15 years, 3 months ago 5 Members · 8 Replies -
Julia Schmid
May 28, 2011 at 1:00 pmI forget to mention that there is also transperancy within the lower third
Ann Bens
May 28, 2011 at 2:03 pmIf you made the lower third in the titler you can save it as a template otherwise save it as a Microsoft avi with the codec set to NONE and bit depth to 32.
Jeff Greenberg
May 28, 2011 at 11:32 pmYou know Premiere Pro lets you import a project, yes? You could build a ‘common’ project and import it into every new project that has that lower third.
Or you could take the existing project and import it into a project you want that lower third in.
Let me know if that makes sense.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website -
Mike Cohen
May 29, 2011 at 12:55 pmTo build upon the other posts. Place the lower third on its own sequence. Then when you need it in another project you can click Import..project…then select the particular sequence you need and it will import only the media needed for that sequence. You used to be able to import titles when they were not saved as part of the project but not since CS3. One would think Adobe would let you import a title or a bin separately but perhaps no one has ever thought of that.
Mike Cohen -
Carly Smith
May 30, 2011 at 11:29 amThis may be irrelevant – but why not create them in Photoshop (which preserves the transparency) and import them into Premiere?
That is how we do ours and if we need to change/edit, the dynamic linking in Premiere auto-updates the .psd file when we update it in Photoshop…
Julia Schmid
June 1, 2011 at 9:45 amI created different movements within the lower third with premiere. I don’t think this is possible with photoshop.
