Activity Forums Adobe After Effects Transparency issues
  • Transparency issues
    Posted by Simon Edwards on April 25, 2009 at 10:25 am
    Hi guys,
    I downloaded some paint splatters and ink drop videos which are just black and white but the background isn’t actually transparent so I can’t really use them. I just wondered if there is anyway I can make the black background transparent. They are just quicktime videos.
    Thanks for your help!
    Simon
    Gunnar Refardt replied 17 years, 5 months ago 5 Members · 5 Replies
  • Roland R. kahlenberg
    April 25, 2009 at 11:26 am
    TO remove blacks, use the Screen Blending Mode. TO remove whites, use the Multiply Blensing MOde.
    Use LEvels and crunch the blacks and whites accordingly to ensure that the whites are pure white and the blacks are pure blacks.
    You can use the Effect>CHannel>Set Matte if you want an Alpha CHannel whihc the BLending Modes don’t provide.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Paul Hennell
    April 25, 2009 at 11:35 am
    Don’t think I’ve ever seen anywhere offering such videos that doesn’t offer a guide/help, but anyway – in a nutshell set your blend mode to multiply. Try other modes or luma key as well to see their effects but multiply is what works best.
    Only in after effects do children get to pick and whip their parents.
    https://hennell-online.co.uk
  • Simon Edwards
    April 25, 2009 at 11:56 am
    amazing that worked fine, thanks so much guys!!
  • Alexander Cama
    April 25, 2009 at 2:41 pm
    You could use the older technique of luma keying, just put your clip in a precomp. Add a white solid and use the luma matte mode. it’s under the alpha matte modes in the little pulldown in the timeline window. (I think they are called the track mattes) This will pull a clean luma key, and when you put the precomp in your main comp you will see that it now has an alpha channel.
    I say older technique because it’s one of the ways video tape worked with keyable video. Just think as your clip as a separated alpha channel.
  • Gunnar Refardt
    April 26, 2009 at 7:13 pm
    I’d rather use Effects/Channels/Shift Channels and set the Alpha to luminance. this way you keep the spatters solid. Please note that white parts of the image stay solid while black parts will be transparent. if your spatters are black on a white background invert the clip before applying Shift Channels.
    hope that helps.
