Activity Forums Boris FX Particle Illusion Transparency in PI 3
  • Transparency in PI 3
    Posted by Renton Maclachlan on May 23, 2013 at 9:42 am
    I want to make a new project which has a transparent layer on which I can place emitters and manipulate them…in front of a background image and behind a cartoon character. I can’t for the life of me see how I can create a transparent layer to work on. I have read threads related to this and experimented somewhat but find that I can only get transparency immediately before rendering which is not what I want. I want to be able to form a transparent layer which I work on until I am satisfied with what I have created…seeing the effects over the background and behind the foreground images…and then render it out.
    So…how do I set the parameters for a project so that I can have a transparent layer to work on?
    I am an owner of PI SE and am evaluating PI 3, but if I can’t do this simple thing, then I may flag away the thought of upgrading…
    Renton Maclachlan replied 13 years, 3 months ago 3 Members · 16 Replies
  • 16 Replies
  • Alan Lorence
    May 23, 2013 at 1:42 pm
    SE is limited to a single layer, so you can’t do it there. Download the pI3 trial, then:
    1) load your background image/clip, place particles on it.
    2) create a new layer on top of this, load your cartoon character (with existing alpha channel) on it.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
  • Renton Maclachlan
    May 23, 2013 at 7:39 pm
    Thanks Alan. I’ll try that tonight.
    Is there anyway to have the particles on a separate transparent layer…which can be inserted at any layer level you want?
  • Alan Lorence
    May 23, 2013 at 7:41 pm
    Sure, just create a layer and put emitters into it.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
  • Renton Maclachlan
    May 23, 2013 at 7:48 pm
    Hmmm…Ok…now I see…duh…Thanks so much.
  • Renton Maclachlan
    May 24, 2013 at 10:51 am
    OK…I got all that to work, thanks so much.
    Now. Is there anyway to turn off particular layers when I want to ‘Save Output’? I put some images on layers so that I could see where I needed to place the paths for the smoke emitter I was using, but now I only want to render out the smoke. I guess I could remove the layers I don’t want…but can I just turn them off?
  • Alan Lorence
    May 24, 2013 at 1:07 pm
    Yep. Use the little icons in the layer window. BG to turn off image.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
  • Renton Maclachlan
    May 24, 2013 at 8:53 pm
    Thanks so much. As you can guess I’m new to this. 🙂 Appreciated.
  • Renton Maclachlan
    May 24, 2013 at 9:34 pm
    Hi again Alan…another question…sorry to bother you…I’m getting there!!
    So…I come to Save Output. My production is going to be used as a layer in a video. So when I output it, I’m faced with the transparency question again.
    In Tutorial 5>Output Options I’m told I can output in avi and then am given a list of codecs which support alpha channel. No where that I can see do the codecs listed appear and when I select avi, transparency is greyed out. I’m aware that I could output as png then import images as a sequence into my video (using Sony Vegas Pro) but I wonder if I can output as a video and thus import into Vegas as a video.
  • Renton Maclachlan
    May 24, 2013 at 9:48 pm
    One other question. I have my smoke looking quite good – coming out from behind a car. The car stops and the cloud ceases moving because the car has stopped.
    But then the engine stops so I want the emitter to stop but the cloud of smoke to carry on. I can’t see how to stop the emitter with its emission of new smoke.
    Sorry if I’m being a pain…
  • Renton Maclachlan
    May 25, 2013 at 2:31 am
    Have found that by exporting as a png with transparency and then importing into Vegas as a sequence is simple…I’m just about there…
