Activity › Forums › Adobe After Effects › Transparency and reflections in Ray-traced 3D?
  • Transparency and reflections in Ray-traced 3D?
    Posted by Ryan Hill on April 23, 2013 at 7:09 pm
    This is interesting behaviour I’ve discovered while playing with Ray-traced 3D. I’m hoping someone can explain why this is handled the way it is and/or a way around it if I don’t want this behaviour.
    Say I have
    A -a layer with Reflection Intensity at 100%
    B -a layer set to Appears in Reflections Only
    C -a layer set to Appears in Reflections Only and transparency at 50%
    And they are arranged such that I can see both B and C reflected in A with C in front of B.
    Since C is transparent, you might expect to see B through C. You would be wrong. Instead, the transparency of C seems to create a transparent hole in A, precisely where C’s reflection appears on A.
    If you switch B to Appears in Reflections On instead of Only, then you can see B through C.
    I guess it is something like the renderer doesn’t treat seeing B through C in a reflection as B appearing “only in reflections” because it’s also being seen through a transparency? Or something?
    Now, being able to add transparent spots to the reflective object like that could have its uses, but what if I did just want the reflection of a transparent object, rather than the transparent reflection of an object?
    Walter Soyka replied 13 years, 5 months ago 2 Members · 1 Reply
  • Walter Soyka
    April 24, 2013 at 3:13 pm
    [Ryan Hill] “I guess it is something like the renderer doesn’t treat seeing B through C in a reflection as B appearing “only in reflections” because it’s also being seen through a transparency?”
    This sounds like a bug to me, and your explanation here seems like a reasonable theory as to its nature.
    I’d suggest you file a bug report [link], and maybe include a link to a project file that illustrates the problem.
    Walter Soyka
