Activity › Forums › Maxon Cinema 4D › Transparency and Gradients….
  • Transparency and Gradients….
    Posted by Christopher Gruber on November 4, 2008 at 7:14 pm
    So, I’ve got a question pertaining to gradients in the transparency channel of a glass material I created.
    Earlier I created a simple colored material which used a gradient in the transparency so that the object (a rectangle) was blue on the left edge and completely transparent on the right edge.
    So, how would I achieve this affect using a glass type material since it already utilizes the transparency channel. Basically, I want an elongated cube (textured with a glass material) to appear as though it disappears or fades to nothing from left to right.
    I was able to get this with a blue material. However, not with the glass material I’ve made.
    Any Ideas?
    Thanks for the help as I get used to learning this program
    Chris
    Brian Jones replied 17 years, 10 months ago 2 Members · 1 Reply
  • Brian Jones
    November 4, 2008 at 8:22 pm
    Use a gradient in the Alpha channel. Alpha channel is much like the transparency except it doesn’t do refraction like transparency and it affects specular, reflection, environment etc (makes them disappear too)
