Activity Forums Creative Community Conversations Translations for Avid editors
  • Translations for Avid editors
    Posted by Trevor Asquerthian on November 2, 2016 at 8:58 am
    In case they are useful to anyone trying out 10.3… please do add any others, or links to where this is done already
    Avid Project = FCPX Library
    Avid Folder = FCPX Event
    Avid Sequence = FCPX Project
    Avid Command Palette = FCPX Keyboard Customisation = ⌥⌘ K (then 3 x tabs to get to search box)
    Avid Project Window = FCPX Library Browser = ⌘ 1
    Avid Timeline = FCPX Timeline = ⌘ 2
    Avid Program Monitor = FCPX Viewer = ⌘ 3
    Avid Source Monitor = FCPX Event Viewer = ⌥⌘ 3 ( ^⌘ 3 to show/hide)
    Avid Effects Palette = FCPX Effects Browser = ⌘ 5
    Avid Mark In = FCPX Set Range Start = I
    Avid Mark Out = FCPX Set Range End = O
    Avid Mark Clip = FCPX Select Clip Range = X
    Avid Top = FCPX Trim Start = ⌥ [
    Avid Tail = FCPX Trim End = ⌥ ]
    Avid Head Fade = Not there yet, closest is FCPX Toggle Audio Fade IN
    Avid Tail Fade = Not there yet, closest is FCPX Toggle Audio Fade Out
    Avid Add Edit = FCPX Blade = ⌘ B
    Avid Export = FCPX Share = ⌘ E
    Avid Timewarp/Motion Effect = FCPX Retime = ⌘ R ( ⌥⌘ R to reset)
    Avid Select Trim Sides = FCPX Select Edges = [ ] \ (add ^ for video, ⇧ for audio)
    Trevor Asquerthian replied 9 years, 9 months ago 4 Members · 6 Replies
  • Noah Kadner
    November 2, 2016 at 12:24 pm
    Folder =Event is not accurate from a metadata/workflow perspective and would lead a poor Avid editor down precisely the wrong path toward learning the advantages of X over all ofher NLEs. They are fundamentally different in functionality. One is a container with zero awareness of its contents while the other is a live metadata placeholder.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Oliver Peters
    November 2, 2016 at 12:54 pm
    More correctly, it should be Avid Bin = FCPX Event.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Jeremy Garchow
    November 2, 2016 at 3:45 pm
    [Trevor Asquerthian] “Avid Command Palette = FCPX Keyboard Customisation = ⌥⌘ K (then 3 x tabs to get to search box)
    Weird. My search box is active as soon as the kb panel opens.
    [Trevor Asquerthian] “Avid Add Edit = FCPX Blade = ⌘ B”
    I find it more helpful to map blade to ‘B’. I then map the blade-all function to ⌘B, and the Blade tool (which switches the Select Tool to a blade, then you click to blade) to ⇧⌘B. I rarely use the blade tool as a mode, but I blade all the time (obviously). Mapping the function to B is much faster and easier, especially with the new shortcuts of Select Above/Below in 10.3.
  • Trevor Asquerthian
    November 2, 2016 at 10:24 pm
    [Oliver Peters]
    More correctly, it should be Avid Bin = FCPX Event”
    You may be right there, although FC Events = AV Folders and FC Folders = AV Bins, kind of
    FCPX Smart Collections = What we have been waiting for from Interplay for about 10 years
    November 2, 2016 at 10:25 pm
    [Noah Kadner] “They are fundamentally different in functionality.”
    The whole thing is fundamentally different. I was attempting to verbalise my understanding. Happy to take crit, obvs.
    November 2, 2016 at 10:30 pm
    [Jeremy Garchow] “My search box is active as soon as the kb panel opens.”
    Mine opens up with the command set dropdown selected (rMBP OSX 10.11.6 FC 10.3 – Build 295518)
    [Jeremy Garchow] “I find it more helpful to map…”
    Yes, I have preferred shortcuts – mainly to match my normal hodge-podge of Avid / FCP7 / Premiere Pro / Sony 9100 / GVG muscle memory & preference to keeping my right hand free… I felt it was better to state the default command set.
    Which has, by and large, had a good deal of thought put into it.
